June 5, 2023 at 7:05 am
FAQParticipantNo, one cannot use the symmetry with beam elements. For the symmetry models the symmetry planes pass through the beams, doing so will require using half cross section at the symmetry plane as well as constraining the beam normal to the symmetry plane. The half symmetry plane has half cross sections defined but it is not assigned to the beams.
- ANSYS Mechanical: Node Merge
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- ANSYS Mechanical: Node Move
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
