Tagged: 19.1, General, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantThe use of FLUID129 assumes a single fluid surrounding the meshed domain, so one cannot use FLUID129 in the application where multiple materials are needed to be modeled.
