March 17, 2023 at 8:58 amFAQParticipant
Parallel processing is available for tetra Octree, prism, and the “quality” smoother. This applies to distributed processors, not distributed memory. The number of processors can be set under “Settings > General.”
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
