June 6, 2022 at 9:57 am
FAQ
ParticipantThe operating system can not change when restarting. For shared memory Mechanical solver (distribute solution unchecked in Mechanical Tools> Solver Process Settings, Advanced.) OS and core counts can be switched for restart. For distributed Mechanical solver (distribute solution checked in Mechanical Tools> Solver Process Settings, Advanced.), OS can be switched, but core counts need to be same.
