Can I resize the graphical window to show the animation of the model while excluding all the blank space?
Tagged: 17, General, mechanical-apdl, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantAs an example, a model with a long x dimension and very small y dimension, the graphical window can be resized. Before making an animation video clip, issue the following commands: /window,1,-1,1.67,-0.1,0.1 Note, it denotes /window,windoe#1,xmin,xmax,ymin,ymax and you can check the online help to find more about this command too. This command will distort the border of the graphical window to a very slender rectangle, long in the x-dir and very narrow in the y-dir. The user can check to see if the object to be animated is inside the border. Then, animate the results and save the animation file. You can insert the animation file in a PowerPoint slide and crop the image to show the interior of the border only.
