General
General
Can I create a plane in Post with fixed dimensions at an offset w.r.t. the origin? For instance, when I specify a YZ-plane with dimensions Y=1m, Z=1m, the plane is plotted centered about the XYZ origin. I would like to set the plane centered about Z=1m.
    • FAQFAQ
      Participant
      This is done by creating a plane with the method ‘Point and Normal’, rather than selecting a YZ plane. The point will be the centre of your plane, and the normal will give its orientation.
