April 5, 2023 at 2:32 pm
FAQ
ParticipantGlyphworks features cannot be accessed using an ANSYS nCode DesignLife license. You can access Glyphworks features from within the ANSYS nCode DesignLife interface, but you need to obtain Supplemental licenses from HBM Prenscia for the desired features.
