June 6, 2022 at 9:57 am
FAQParticipantAnsys nCode DesignLife cannot perform fatigue analysis in accordance with either the ASME Boiler and Pressure Vessel Code Section III or Section VIII, Div 2. The only ANSYS tool that can perform fatigue evaluations in accordance with the ASME B&PV Code is the Mechanical APDL fatigue module.
