May 15, 2023 at 8:32 amSolutionParticipant
see attached pdf
1. Using%20a%20subset%20of%20Named%20Selections%20in%20ANSYS%20nCode%20DesignLife.pdf
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
