Can Acoustics analysis (to calculate pressure load) be used as part of an upstream system for topology optimization?
Tagged: 19, analysis-techniques, mechanical, optimization, structural-mechanics
March 17, 2023 at 8:59 am
FAQ
ParticipantYes, but user has to employ External Data to import the pressures from the acoustic run into the static analysis for optimization. (R19.0 does not support linking of Acoustic analysis into a structural analysis.)
