June 6, 2022 at 9:57 am
FAQ
ParticipantYes, for an example see Example 9.8: Linear Perturbation Substructure Generation Pass Followed by Use and Expansion Passes, found in the help manual, by opening Tools->Go To Page… and pasting the following: help/ans_str/strlinpertinputs.html
