June 12, 2025 at 1:40 pm
FAQParticipantBody of Influence in Ansys Discovery 2025R2 provides flexible mesh control by allowing you to locally control mesh size in specific regions of your geometry. It enables more refined meshing around critical areas while maintaining coarser mesh in less important regions.
In the following video, we will explore how to create and implement BOI for external fluid flow analysis on an Ahmed body. We will also demonstrate how to set up multiple bodies of influence with different local sizing settings to optimize your simulation mesh.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
