January 25, 2023 at 7:16 am
FAQParticipantThe airfoil area is the section area for the blade on a given span layer. It’s calculated by numerical integration (trapezoidal rule) between the pressure and suction sides.
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
