August 25, 2023 at 12:16 pm
Solution
ParticipantBatch runner for Parallel (Autodyn). Please make modifications in the attached batch file. Set the variables below as they are on your machine. Also make sure MPI_ROOT is set and that the executable names match the version you use.
1. 2027263.zip
- How to resolve “Error: Invalid Geometry”?
