Tagged: 2022 R1, Analysis (HFSS), hfss, solution setup
January 31, 2023 at 9:25 am
FAQParticipant・HFSS では、Direct と Iterative ソルバーにより行列演算を行います。 ・2022R1 から Auto Select Direct/Iterative 機能により、いずれかのソルバーが自動で選択され、解析速度向上とメモリ使用量削減を実現します。 詳細は添付の資料をご覧下さい。 キーワード:Direct, Iterative, Auto Select, 行列演算, 自動選択
- [info] Failed to delete temporary files on server ‘localhost’. Found File ~ . You may want to manually delete directory ‘~’.
- [error] Solving adaptive frequency …, process hf3d error: Matrix solver exception: file I/O failure.
- [error] Doing Multiple Region Initial Mesh Assembly, process mesh3d : Unexpected internal software error. Please contact Ansys technical support
- [info] Normal completion of simulation on server: Local Machine.
- MPI 分散計算が行えない場合のチェック項目
- 一台の PC に複数の NIC (Network Interface Card) が有効な場合の Intel MPI の必要設定について
- [warning] For magnetic materials it is recommended to solve for at least 5 inductance passes.
- [info] Failed to start next variation. Analysis will stop when all running variations are finished.
- [info] A variation (変数条件) has been requested using the following machines: Local Machine
