September 26, 2022 at 9:59 am
Watch & LearnParticipantThe performance of an asphalt plant depends upon the interaction of many different processes. Astec has made substantial improvements in its ability to accurately simulate these different processes, generating large quantities of disparate data whose impact on the design issues at hand is often difficult to understand. Astec brings meaning to this data by combining results from different simulation tools and different design alternatives. Animations, graphs and explanatory text are merged into a single composite image using ANSYS EnSight. This gives the decision-maker everything he or she needs to know to improve product performance. In this case study video, you will see how one of their engineers used ANSYS Discovery to test several design iterations and finalize a solution, much faster than they otherwise could have done.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
