As per the R18.2 Capability chart SCDM supports LiveReview. However I cannot locate this feature in SpaceClaim.?
June 5, 2023 at 7:05 am
FAQParticipantThis is a mistake in the Capability Chart and will be correceted for next releases. SCDM does not support LiveReview. One needs a Standalone Ansys SpaceClaim license for this. Also there are no plans to support LiveReview in SCDM in near future.
