Are there any reference papers to validate the sample material properties found in Engineering Data specifically for Additive Manufacturing applications?
January 25, 2023 at 7:34 am
FAQParticipantPlease refer to the list below: J. R. Chukkan, M. Vasudevan, S. Muthukumaran, R. R. Kumar and N. Chandrasekhar, “Simulation of laser butt welding of AISI 316L Stainless steel sheet using various heat sources and experimental validation,” Journal of Materials Processing Technology, vol. 219, pp. 48-59, 2015. P. D. Desai and C. Y. Ho, “Thermal Linear Expansion of Nine Selected AISI Stainless Steels,” Center for Information and Numerical Data Analysis and Synthesis (CINDAS), West Lafayette, IN, 1978. C. Y. Ho and T. K. Chu, “Electrical Resistivity and Thermal Conductivity of Nine Selected AISI Stainless Steels,” Center for Information and Numerical Data Analysis and Synthesis (CINDAS), West Lafayette, IN, 1977. C. S. Kim, “Thermophysical Properties of Stainless Steels,” Argonne National Laboratory, Argonne, IL, 1975. A. A. Olleak, M. Nasr and H. A. El-Hofy, “The Influence of Johnson-Cook Parameters on SPH Modeling of Orthogonal Cutting of AISI 316L,” in 10th European LS-DYNA Conference, Würzburg, Germany, 2015. The International Nickel Company Inc., “Austenitic Chromium-Nickel Stainless Steels – Engineering Properties at Elevated Temperatures,” in INCO Databook 2980, 1968.
