June 5, 2023 at 7:05 am
FAQ
ParticipantThe Infill pattern option is only available to users with the STL Prep add-on module (the Facets tab). In the Facets tab, go to the Shell tool. In the Shell options, change the Infill type from None to Basic (or Custom) to access the library of infill pattern types.
