General
General
ANSYS SpaceClaim: What are various options available for controlling spin?
    • FAQFAQ
      Participant
      The basic navigation tutorial is here, but it’s a bit outdated: http://www.spaceclaim.com/en/Support/Tutorials/Essentials/SpaceClaim_Basics_Tutorials.aspx?t=70# In the latest version of SpaceClaim, the orientation tool on the bottom left also has a dashed circle around it. You can click and drag this circle to rotate the model in the same plane as your screen. In other words, it will spin the model as if on a turn table. Aside from this, the only other option for controlling the spinning is to use the Move tool. In this case you would have very specific controls for rotating about the X, Y, or Z axis of the move tool itself.
