March 17, 2023 at 8:59 am
FAQ
ParticipantThe Shrinkwrap tool allows you to create a single, faceted model that can be sent to a 3D printer. Shrinkwrap creates a faceted wrapper around the model that closes gaps. It has controls like “Select tight fit faces or facets,” “preserve features,” and “secondary size” which can be used to further capture underlying geometry more accurately. Shrinkwrap helps to overcome any spikes, sharp edges and irregularly distributed facets and generates a smooth surface. You need to have a closed facet model to generate shrinkwrap properly.
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/06/Ansys-Cloud.jpeg)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/03/Optical-1-1.png)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/03/Geko_Video-1-1.png)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/06/EnSight_PP.webp)
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
