ANSYS SpaceClaim: The translators are not working correctly – How do I reset the translator options?
Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General
June 5, 2023 at 7:05 am
FAQParticipantFirst check if you have purchased the translators as part of your license package. If you have and need to reset the translator options, follow these steps: From the Windows Start Menu, search for “”regedit”” Follow these paths and delete both of the keys listed here: You can also go to the Windows Registry and remove the following key(s): HKEY_CURRENT_USER > Software > SpaceClaim > LicenseReset > Reset HKEY_CURRENT_USER > Software > SpaceClaim > Primary > LicenseType Restart SpaceClaim and see if the translator options are back.
- Skewness in ANSYS Meshing
