ANSYS SpaceClaim: Some users are receiving the following license expiration message when launching SpaceClaim: “Your license will expire in 33 days”. What is the issue and how to solve it?
June 5, 2023 at 7:05 am
FAQParticipantThe message the user is receiving seems to make sense. The license you’re mentioning is going to expire, and the message says it’s going to expire in about a month. NFR licenses that are located in the partner portal are good for one year. At the end of that year a new one needs to be sent to that end user. These licenses are different from the floating licenses that are being used.
