ANSYS SpaceClaim: I want to Pull an end surface of curved body, along the given direction but it continues to follow curved path. How to do it?
June 5, 2023 at 7:05 am
FAQParticipantThere can be two approaches to do it; Approach 1: – Select the end face along with its boundary edges under Pull command. – Select the Pull Direction and pull it. Approach 2: – Select the end face and Copy/Paste it. – Select the new face under Pull command to pull it along given direction.
