ANSYS SpaceClaim: I like to use GB default as my detailing option setting and set it to GB default, but when I restart Spaceclaim, it backs to ASME default automatically, how can I save this setting?
August 25, 2023 at 12:16 pm
FAQParticipantDirectly above the ASME, ISO, GB default buttons, there is an option to choose these settings for this document, or all new documents. Refer attached image which shows this option. Please make sure it’s set to all new documents before changing the setting.
