ANSYS SpaceClaim: I have unitless STL files. Depending on the stl file I choose, sometimes it interprets the result in meters, and sometimes in inches. Why is it not consistent?
August 25, 2023 at 12:15 pm
FAQ
ParticipantThe default setting when importing an STL is to assign units “Automatically”. Refer attached image which shows this option. This leaves some room for interpretation. If you’d like to specify the units, you can do this manually from the File > Open STL menu. You can also define a global setting in File > SpaceClaim Options > File Options > STL
- Skewness in ANSYS Meshing
