May 15, 2023 at 8:32 am
Solution
ParticipantSpaceClaim gives very easy to use interface for geometry creation. It has all essential features under sketching along with 3D geometric operations.. You can insert Standard Holes as per industrial notations. Keywords: Pull,Move,Sketch, Insert, Standard Hole
1. 2052824.zip
2. 2052824_Captions-EN.mp4
- How to resolve “Error: Invalid Geometry”?
