May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim has variety of features while dealing with geometry creation. In sketching, you can use Mirror Line feature for creating symmetric sketches. You can also give dimensional references in Cartesian or Cylindrical CS from any specific feature. Keywords: Pull,Move,Sketch, Mirror Line
1. 2052819.mp4
