May 15, 2023 at 8:32 am
SolutionParticipantIn this last part of video, we will see how to assemble those separate bodies, locate them accordingly. After that, we can perform geometric operations like Split Body, Combine and finally add rounds to have final geometry. Keywords: Pull, Assembly, Move, Sketch
1. 2052815.zip
2. 2052815_Captions-EN.mp4
