ANSYS Mechanical 19.2, when run on a Windows Server 2012 operating system, using Microsoft MPI (MS MPI). Fails with the error, The procedure entry point MPI_Get_library version could not be located in. C:Program FilesANSYS Incv192ansysbinwinx64MPIMSMPIAnsMPI.dll
March 17, 2023 at 9:01 am
FAQParticipantThis error can indicate that the version of Microsoft MPI software installed on the system, is not compatible with the ANSYS Mechanical software. The version of the MS MPI software , with which the ANSYS Mechanical software has been tested, can be found in the ANSYS help text at, https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/ans_dan/dan_configdan.html Mechanical APDL Parallel Processing Guide 4.1. Configuring Distributed ANSYS 4.1.1.1. MPI Software Windows HPC Server 2012 x64Microsoft HPC Pack (MS MPI v7.1)
