Tagged: aggressors, antenna coupling, coupling, electromagnetic interference (EMI), electronics, EMIT, hfss, insertion loss report, pcb, radiated emissions, radio, radio-frequency interference, receivers, return loss report, RF Coexistence, RF Desense, RFI, smartphone, spread spectrum clocks, WiFi receiver
July 4, 2022 at 7:00 am
Watch & LearnParticipantIn this video, we run a Desense analysis for the improved design in EMIT. The video also offers a good overview of the EMIT user interface. Two metrics, namely EMI Margin and Desense are utilized in EMIT to identify all possible offenders and eliminate interference completely for this design. A commonly employed frequency modulation technique in electronics design known as Spread Spectrum Clocking is also described and defined in EMIT to significantly reduce electromagnetic interference (EMIT). All contributors of interference occurring within and outside the tuned channel are assessed and eliminated from the modified design of the PCB.
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Set “Non-Model” Property to an Object in 3D Layout
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- How to Create Bondwires in 3D Layout ?
