General
General
Ansys FreeFlow FAQs and Tips
    • SolutionSolution
      Participant
      FreeFlow FAQs & Tips
      Welcome to Ansys FreeFlow FAQ and Tips Center.
      Navigate through contents below and find answers and tips  from our team of experts to enhance your Ansys FreeFlow engineering simulations.
      /FreeFlow SPH Adaptive Size
      What is SPH Adaptive Size in Ansys FreeFlow?
      SPH Adaptive Size is a capability in Ansys FreeFlow that automatically adjusts the size (resolution) of SPH elements during a simulation… Read full FAQ
      How is SPH Adaptive Size different from standard SPH in Ansys FreeFlow?
      With SPH Adaptive Size, the element size can change locally during simulation, the resolution is higher only in selected regions or near boundaries… Read full FAQ
      How does SPH Adaptive Size work in Ansys FreeFlow?
      SPH Adaptive Size in Ansys FreeFlow works by refining and coarsening SPH elements in a controlled, hierarchical manner, improving accuracy only where needed while keeping overall computational cost low… Read full FAQ
      What are the main benefits of using SPH Adaptive Size, and what types of applications benefit most from it?
      SPH Adaptive Size key benefits include, Improved accuracy in critical flow regions, Reduced computation time compared to uniform fine resolution… Read full FAQ
      Which solvers support SPH Adaptive Size?
      SPH Adaptive Size is supported with the following solvers, Implicit Incompressible SPH (IISPH) — Default and recommended solver…. Read full FAQ
