An initial coarse ICEM mesh will import into FLUENT just fine, but whenever I go back and refine the mesh in ICEM use the refinement feature under ‘Pre-mesh Params’, the mesh check fails in FLUENT. The actual error states… WARNING: 486 cell(s) on zone 12 have node(s) not connect to all faces (on 1000000)………… Done. WARNING: Mesh check failed. Is this something to worry about?
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: premesh, icem, refinement
1. 2050860.pdf
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
