An attempt to uninstall Ansys EM by using silent mode using the following command results in failure. C:Program FilesAnsysEMAnsysEM19.3Win64Uninstall>setup.exe /z suppressconfirmation /removeonly >>>>> Setup has detected that the following applications are still running C:Program FilesAnsysEMAnsysEM19.3Win64Uninstallsetup.exe Close the applications and choose ‘OK’ to continue, or choose ‘Cancel’ to exit setup. >>>>>
- setup.exe /z suppressconfirmation /removeonly >>>>> Setup has detected that the following applications are still running C:Program FilesAnsysEMAnsysEM19.3Win64Uninstallsetup.exe Close the applications and choose ‘OK’ to continue, or choose ‘Cancel’ to exit setup. >>>>>" target="_blank" rel="nofollow" title="LinkedIn">
- setup.exe /z suppressconfirmation /removeonly >>>>> Setup has detected that the following applications are still running C:Program FilesAnsysEMAnsysEM19.3Win64Uninstallsetup.exe Close the applications and choose ‘OK’ to continue, or choose ‘Cancel’ to exit setup. >>>>>" target="_blank" rel="nofollow" title="whatsapp">
- setup.exe /z suppressconfirmation /removeonly >>>>> Setup has detected that the following applications are still running C:Program FilesAnsysEMAnsysEM19.3Win64Uninstallsetup.exe Close the applications and choose ‘OK’ to continue, or choose ‘Cancel’ to exit setup. >>>>>" target="_blank" rel="nofollow" title="reddit">
- setup.exe /z suppressconfirmation /removeonly >>>>> Setup has detected that the following applications are still running C:Program FilesAnsysEMAnsysEM19.3Win64Uninstallsetup.exe Close the applications and choose ‘OK’ to continue, or choose ‘Cancel’ to exit setup. >>>>>" target="_blank" rel="nofollow" title="facebook">
March 17, 2023 at 9:01 am
FAQParticipantworkaround: copy “C:Program FilesAnsysEMAnsysEM19.3Win64Uninstall” to “C:Program FilesAnsysEMUninstallANSYS Electromagnetics Suite 19.3 (64-bit)” and run: “C:Program FilesAnsysEMUninstallANSYS Electromagnetics Suite 19.3 (64-bit)setup.exe” /z suppressconfirmation /removeonly.
