After installing ANSYS EM 17.1 on a Windows 7 machine customer received error addressed in solution 2042253. After using the configureThisMachine.exe from the solution, user received the following error: “ansysedt.exe – System Error The program can’t start because MSVCR110.dll is missing from your computer. Try reinstalling the program to fix this problem”
January 25, 2023 at 7:28 am
FAQParticipantResolution for this error was to install the C++ redistributable
