After I solve a large model in Workbench Simulation (ANSYS result file is several GB), “Evaluate All Results” takes a long time. What is a possible reason for this?
Tagged: 11, General, Mechanical (f. Simulation), structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantWhen using “Evaluate All Results,” open up the Windows Task Manager, under “Performance” tab, to see “Physical Memory” information. If the System Cache is large and Available memory is very small, that means that the Windows operating system is taking up all the memory for caching. While this behavior generally produces good performance in retrieving results, if the result file is too large, a performance penalty can occur as a result of physical memory being limited. If this is the cause, adding more physical memory would help performance.
