After changing a driving dimension in SCDM, the solid geometry is updated but the fluid volume created by Volume extract is not.
March 17, 2023 at 8:58 amFAQParticipant
This is the expected behavior: Working with SpaceClaim interactively you will need to expand the corresponding Volume component in the structure tree, then right click on the Volume body and select “Update Volume Body as Created”. Alternatively, in a Workbench project, changing the corresponding parameter in the parameter manager and updating, for example, the meshing component (or design points or the whole project) will result in an automatic update of the extracted volume.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
