After applying AnsysEM2020R2.4 patch, starting AEDT results in the following error popup: The procedure entry point ?SetUseLoopbackAddressForLocalSolve@AnsoftCOMGlobalslnitializer@@QEAAX_N@Z could not be located in the dynamic link library C:Program FilesAnsysEMAnsysEM20.2Win64Desktop.dll.
March 17, 2023 at 9:00 am
FAQParticipantCustomer was running a prerelease build AnsysEM2020R2 and applied the 2020R2.4 patch. To resolve, completely uninstall AnsysEM2020R2 and confirm all files and directories have been removed. Then reinstall the official version AnsysEM2020R2
