Additive Print: Is it possible to delete an auto generated support within the Additive Print Session?
Tagged: 1.2.1, 19.1, Additive Print, additive-manufacturing, Desktop, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantNo. Support elements that are automatically generated within Additive Print cannot be deleted directly within the Additive Print application. Keep in mind that the supports are being generated based on the angular orientation relative to the base plate to achieve a stable build. So removing these supports without changing the part orientation might produce a build failure. With this in mind, first consider re-orienting the build part relative to the base plate to eliminate the need for the unwanted supports. If a customized support is needed and auto generation is inadequate, it is possible to take the resulting auto generated support geometry file from Additive Print into Spaceclaim or some other 3rd party CAD tool, merge it with the build part, modify the supporting geometry as desired, read back into the the Additive Print Session and suppress the auto generated support tool.
