General
General
Additive Print: In a scan pattern simulation, what is transferred/extracted from the build file?
    • FAQFAQ
      Participant
      As of v19.2, additive print only extracts the fill scan vectors (no process parameters). Note that we are also not calculating the contours, so even when we are providing thermal history it is being done for the scan vectors and you will not see the effects of the contours.
