Additive Print: Are there any inherent limitations to the calibration of strains being applied in case of the Direct Energy Deposition (DED) method ?
April 5, 2023 at 2:32 pm
FAQParticipantThere is no theoretical limitation that would apply to DED or any other Additive Manufacturing machine. If the scan vectors can be read correctly, there’s no reason why Scan Pattern-based strain wouldn’t also work to provide more fidelity. But please note that the thermal portions wouldn’t work correctly. Note that DED cannot be currently used in Additive Print.
