Postprocessing
Postprocessing
Adding axis to a contour plot in EnSight
    • FAQFAQ
      Participant
      Axes plot can be added to a contour plot by turning on visibility of the 2D bounds. To do this: 1. In the view menu, turn of the bounds visibility. 2. In the Viewport settings, set the viewport to be 2D. Right-click on the viewport -> Edit to open the ‘create/edit viewports ‘ dialog box. Change ‘View Dimension’ from 3D to 2D. The axes, thus created, will use the dimensions of the model. If you wish to normalize them, you’ll need to normalize the model part itself (by double-clicking on the part in the part-list, and set a scaling / offset factor). You should be able to label the axes using text-annotations. Keywords: display axes, contour plot, EnSight, bounds visibility
