Accurate calculation of heat transfer coefficient (HTC) during conjugate heat transfer (CHT) modeling in CFD post
March 17, 2023 at 1:10 pm
Solution
ParticipantCFX / Fluent calculates heat transfer coefficient (HTC) at the wall using the fluid temperature at the first node / first cell from the wall as an approximation of the free stream temperature outside the thermal boundary layer. As the first node / cell from the wall may not be outside the thermal boundary layer, this method over-estimates the HTC. A more accurate method is presented in this material. Please refer to the attachment for details. Keywords: heat transfer coefficient (HTC), conjugate heat transfer (CHT), wall adjacent temperature
1. 2054957.pdf
- Skewness in ANSYS Meshing
