A multiphase VOF simulation of water droplets on a surface – predicts (nonphysical) “movement” of air-water interfaces
March 17, 2023 at 1:11 pm
Solution
ParticipantPlease find the attached solution. Please note that this solution is prepared by our Channel Partner – ENTUPLE
1. VOF_contact_angle_specification.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- What do “incomplete” DPM particle tracks mean?
- How do I use porous media in a multiphase flow?
