A hot liquid droplet is exposed to a colder gaseous surrounding. Solidification/Melting model is activated to simulate the solidification of the liquid droplet. No solidification happens although the temperature fell below the defined Solidus Temperature. Why?
Tagged: 16.1, fluent, fluid-dynamics, MP - Free Surface Flow, multiphase, phase-change
January 25, 2023 at 7:17 am
FAQParticipantA hot liquid droplet is exposed to a colder gaseous surrounding. Solidification/Melting is activated to simulate the solidification of the liquid droplet. Although the temperature has fallen below the defined Solidus Temperature in parts of the liquid region for some time steps, these parts are still not solidified. What could be a reason for this behavior? In the material panel of the liquid which is expected to melt or to solidify it is not only important to set the Solidus and Liquidus Temperature properly, but also the Pure Solvent Melting Heat. The default for this is zero and has to be modified to allow the phase change.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
