January 31, 2023 at 9:59 am
FAQParticipant以下の文献リストを参照してください。 J. R. Chukkan, M. Vasudevan, S. Muthukumaran, R. R. Kumar and N. Chandrasekhar, “Simulation of laser butt welding of AISI 316L Stainless steel sheet using various heat sources and experimental validation,” Journal of Materials Processing Technology, vol. 219, pp. 48-59, 2015. P. D. Desai and C. Y. Ho, “Thermal Linear Expansion of Nine Selected AISI Stainless Steels,” Center for Information and Numerical Data Analysis and Synthesis (CINDAS), West Lafayette, IN, 1978. C. Y. Ho and T. K. Chu, “Electrical Resistivity and Thermal Conductivity of Nine Selected AISI Stainless Steels,” Center for Information and Numerical Data Analysis and Synthesis (CINDAS), West Lafayette, IN, 1977. C. S. Kim, “Thermophysical Properties of Stainless Steels,” Argonne National Laboratory, Argonne, IL, 1975. A. A. Olleak, M. Nasr and H. A. El-Hofy, “The Influence of Johnson-Cook Parameters on SPH Modeling of Orthogonal Cutting of AISI 316L,” in 10th European LS-DYNA Conference, Würzburg, Germany, 2015. The International Nickel Company Inc., “Austenitic Chromium-Nickel Stainless Steels – Engineering Properties at Elevated Temperatures,” in INCO Databook 2980, 1968.
- 任意の座標での結果を表示したい
- プローブで出力した結果をファイルにエクスポートする方法
- Workbench Mechanicalのデフォルトの[背景スタイル]/[背景色]を変更することは可能ですか。
- 疲労解析ソフトウェアを用いずにランダム振動疲労を計算する方法
