Tagged: 2021 R2, Analysis (HFSS), hfss, Remote/Distributed Solving
January 31, 2023 at 9:25 am
FAQParticipantWindows の非アクティブディレクトリ環境の場合、全ての分散計算端末で Intel MPI の認証作業が必要です。操作は以下になります。 1. コマンドプロンプトを起動して Mpiexec –register と入力する 2. ID として空欄を入力 3. Password として Windows のログイン Password を入力
- [info] Failed to delete temporary files on server ‘localhost’. Found File ~ . You may want to manually delete directory ‘~’.
- [error] Solving adaptive frequency …, process hf3d error: Matrix solver exception: file I/O failure.
- [error] Doing Multiple Region Initial Mesh Assembly, process mesh3d : Unexpected internal software error. Please contact Ansys technical support
- [info] Normal completion of simulation on server: Local Machine.
- MPI 分散計算が行えない場合のチェック項目
- 一台の PC に複数の NIC (Network Interface Card) が有効な場合の Intel MPI の必要設定について
- [warning] For magnetic materials it is recommended to solve for at least 5 inductance passes.
- [info] Failed to start next variation. Analysis will stop when all running variations are finished.
- [info] A variation (変数条件) has been requested using the following machines: Local Machine
