August 25, 2023 at 12:16 pm
Solution
ParticipantA: Starting on R17, it can be done directly connecting two analysis systems as a solid-solid submodel is done. Both force and displacement submodels are supported. See documentation attached: 2043647_Beam_Submodeling.pdf
1. 2043647_Beam_Submodeling.pdf
- How to resolve “Error: Invalid Geometry”?
