Could you please provide an example of setting the simple entrance, outlet and initialization of the open channel?
Tagged: 17, BCs & Interfaces, fluent, fluid-dynamics, materials, MP - Free Surface Flow
August 25, 2023 at 12:15 pm
SolutionParticipantPlease refer to the attachment to access the solution.
1. 2043538.pdf
2. 2043538pp.pdf
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
