September 26, 2022 at 9:53 am
FAQParticipantDownload the file here
Accessing Discovery on the Cloud is a great way to remove hardware limitations and access your simulation results from any location.Discovery on Ansys Cloud can be run through the Ansys Cloud Portal or it can be run through our desktop Discovery Cloud Launcher. In order to launch Discovery from your desktop, both of the below links will need to be downloaded and installed.
The first link will install a transfer agent allowing you to upload and download files securely to the cloud. This will also create a connection between the cloud servers and your desktop.
The second link will create a desktop application allowing you to easily set up a profile and access the cloud with a single click. Please use the attached PDF as a helpful guide to get started.
Discovery on Ansys Cloud requires an additional subscription. If you do not have a subscription to the Ansys Cloud environment, more information on purchasing one can be found here or a free trial and be requested here.
To access Discovery on the Ansys Cloud, please install both the File Transfer Agent and Discovery Cloud Launcher below, then run the Launcher.
File Transfer Agent
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Subscription license – Command line options
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
